Autodesk Robot Structural Analysis
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
panel reaction output rather than FE nodal reactions?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Afternoon All,
I've been trying to export the base reactions for an RC building made up of FE meshed panels. Unfortunately Robot seems to only export reactions for every individual FE node, leading to a HUGE file of thousands of nodes.
I just want basic uniform distributed load KN/m, and KNm/m reactions along the base of the walls in order to design up a chunky raft outside of Robot. Is there any add-in / plug-in that I could use to acheive this with minimal pain?
I'd rather not have to work out approximate reactions by hand, or absorb a large volume of time decyphering the FE nodal reaction output. Expert help appreciated! ![]()
Scott
Re: panel reaction output rather than FE nodal reactions?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
http://docs.autodesk.com/RSA/2013/ENU/filesROBOT/G
Display results at the bottom edge of walls. You may add cut (wall) length in the display of the Reduced Results table so that you know the value of bending per unit length if needed.
Artur Kosakowski
Support Specialist
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks Artur
Ok I'll see if I can get some useful results from that. The building has many wall panels at foundation level though.... Is the option of displaying foundation reactions per m length in the development list for Robot? It seems pretty fundamental. It wasn't a pleasant suprise to find out this was missing last week.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Artur Kosakowski
Support Specialist
Product Support
