• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Member
    igniusis
    Accepted Solution
    no materials in datebase
    297 Views, 7 Replies
    12-06-2011 11:32 AM
    hello,
    I am using ARSA 12, I am searching S275 for days and can't find it, my datebase is empty (pic1). I have installed  service pack 3  , but it stll remains empty.
    Also when creating tapered section my ''add'' button is inactive (pic3), what I am doing wrong ?
    thanks for answers
    Product Support
    Re: no materials in datebase
    12-07-2011 12:38 AM in reply to: igniusis
    Please exit Robot and check whether EUROCODE.xml file exists in the following folder (AppData may be hidden folder):
    C:\Users\username\AppData\Roaming\Autodesk\Structural\Common Data\2012\
    If yes please rename or delete it, restart Robot and check availability of materials.
    If no or materials are still not displayed after above operations please check whether EUROCODE.xml file exists in the following folder and you have read rights in it (ProgramData may be hidden folder):
    C:\ProgramData\Autodesk\Structural\Common Data\2012\Data\Mate\
    Your screen capture suggests that "Add" button is active. Can you try once again?
    If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
    Best regards,
    Pawel Pulak
    Support Specialist
    Product Support
    Autodesk, Inc.
    Member
    igniusis
    12-07-2011 06:47 AM in reply to: pp2008
    Thanks for answer.
    I tried everything you said, but still material list does not apear.
    I had same error like this http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Error-in-reading-sections-data-check-the-sec... , now i can add sections only from datebase, but I can't add from ''new section'' because I always getting error - ''Incorect parameter section not displayed from base''. pic4
    Creating tapered section ''add'' button is active, but it is pointless, nothing happens then I click it.
    I think problem is same, my ARSA do not see eurocode or something.
    Maybe i have installed SP 3 badly, dont know...
    Product Support
    12-07-2011 07:33 AM in reply to: igniusis
    Igniusis, please check private message clicking the envelope  icon:
    Pawel Pulak
    Support Specialist
    Product Support
    Autodesk, Inc.
    Member
    igniusis
    12-09-2011 12:56 AM in reply to: pp2008
    Problem solved :smileyhappy:
    I changed regional settings (tools>preferences>languages>regional settings) and everything appeared : materials, section list. Everything is working properly now.
    Thanks pp2008 for helping :smileyhappy:
    New Member
    KerliKaasik8213
    02-22-2012 11:41 PM in reply to: igniusis
    I have similar problem. I don't have materials in Eurocode database.
    I changed regional settings, but nothing changes.
    I tried also first recommendation about deleting file EUROCODE.xml, but I don't have such file in these directories.
    I have only 1 file EUROCODE.xml, but its located in: C:\Autodesk\ASD_2012_English_Win_32bit\x86\ASD\Program Files\Root\STRUCTURAL_COMMON_DATA\Data\Mate.
    This is not ARSA file, but ASD.
    Under ARSA I found only EUROCODE.mdb, located in: C:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2012\RESC\Data\Mate.
    What else should I do to make this work?
    Product Support
    02-23-2012 12:17 AM in reply to: KerliKaasik8213
    Your screen capture suggests that you are using RSA 2012 in Win XP so look for EUROCODE.xml in the following folder:
    c:\Documents and Settings\username\Application Data\Autodesk\Structural\Common Data\2012\
    Attention: Application Data is a hidden folder so to see it it may be necessary to set "Show hidden files and folders" in Tools>Folder Options>View tab of Explorer.
    Pawel Pulak
    Support Specialist
    Product Support
    Autodesk, Inc.
    New Member
    KerliKaasik8213
    02-23-2012 12:24 AM in reply to: pp2008
    Thank you very much!
    This solved my problem! :smileyhappy:
