• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    New Member
    need helps understanding results
    119 Views, 3 Replies
    01-09-2013 03:05 AM
    Hi there, I am quite new to Robot and I am trying to analyse stiffness here and I guess something is wrong but I dont know what, I cant get the correct displacement or moments even (displacement is zero). my structure is timber framed with clt panels please help
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: need helps understanding results
    01-09-2013 03:28 AM in reply to: jihanjulaihi
    Try to increase the precision of display of values adding some zeros after the point/comma (0.1234). Job Preferences > Other > Displacements.
    If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    New Member
    01-09-2013 03:44 AM in reply to: Artur.Kosakowski
    That work but I still dont get why it is written Dis 0mm and why are the values negative? Does that indicates the direction of the axis?
    Product Support
    Artur.Kosakowski
    01-09-2013 05:22 AM in reply to: jihanjulaihi
    I assume that you set the diagram scale as 0 ..
    .. and the direction of the  local Z axes of the horizontal panels are upwards whereas the actual displacements are downwards.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
