Autodesk Robot Structural Analysis
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
moving load direction
- Highlight
- Email to a Friend
I want to model a moving carriage on a mast, this carriage applies coupling moments on the mast legs. I assigned a vehicle with loads as couples in opposite direction.
when I applied the moving load, it is assigned in a plane perpendicular to the plane in interest. I tried to play with the Gamma angle in the Route parameters but it rotates the load only but not the plane of the vehicle as per attached file.
I want the moving load to move in +Z direction, the vehicle is in XZ plane and the loads are in Y direction (all axis in Global dirctions)
so to make this work to the current model, I need to rotate the whole vehicle about the Z axis counterclock wize by 90 degress.
Re: moving load direction
- Highlight
- Email to a Friend
See the attached picture.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Support Specialist
Product Support
Autodesk, Inc.
- Highlight
- Email to a Friend
Thanks alot Artur
