• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Distinguished Contributor
    faisal.aaouatif
    Accepted Solution
    meshing or not ?
    161 Views, 3 Replies
    11-05-2012 03:19 PM
    even if we freeze the meshing on a model , after running calculations , its seems that process of remeshing start again, which can takes a long time for large models.
    so , would recommend anyway this workflow, or it would be satisfactory (no problem with results) if we  ask to the software to not regenerate the meshing (after a freezing the first one) at all,  and then begin the calculations.
    thks
    Please use plain text.
    Product Support
    Re: meshing or not ?
    11-05-2012 11:26 PM in reply to: faisal.aaouatif
    It is just a progress - merging nodes on commmon egdes etc.
    Do you use kinematic links?
    Send us model to check.
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    faisal.aaouatif
    11-06-2012 12:49 AM in reply to: RG_Adsk
    im not sure that the hole process of meshing is reloading after freezing (it seems not....) but the point is that if , after freezing it , could the fact of not generating the model - see attachment please (which can save a lot of time ) and run calculations affect the results.
    For meshing i use the option 'Automatic selection of meshing method'
    thks
    Product Support
    11-06-2012 03:05 AM in reply to: faisal.aaouatif
    IN case of making anly changes in model (properites, loads, geometry) it is recommended to run calcaulations with model generation.
    IN case of changing calculation parameters for existing load cases (I do not mean load to mass conversion) you can skip this step
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
