• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Active Member
    memoalcr
    manual load combination factors - load types - load nature
    102 Views, 1 Replies
    02-14-2013 02:19 PM
    If I define a load combination
    LIVE=(LL1 + LL2)
    and in load types I assign "live" nature to it; when I try to manualy create a combination, say
    COMB1 = 1.6 LIVE
    and the load factor for "live" is set to 1.6 in the load factor table; ifI select LIVE from the "case list" column and transfer it to "List of cases in combination" column; RSA assigns a factor of 1.0 instead of a 1.6.
    Seems to me that RSA does not recognize the nature of the load combination LIVE.
    How do I assign the "live" nature to a combination?
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: manual load combination factors - load types - load nature
    02-14-2013 11:43 PM in reply to: memoalcr
    This should not happen unless you define SLS combination type rather than ULS (1.0 is the default factor for SLS combinations for all loads). I indicated the steps for EC regulation on the attached picture. Mind taht at any moment you can overwrite the default load factor with the 'needed' one.
    Artur Kosakowski
    Support Specialist
    Product Support
