• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Valued Mentor
    tony.ridley
    Re: lifting the construction
    04-23-2012 06:31 AM in reply to: mortel09
    normally, just use the spreader on two sides, it will be stable for regular shaped geometry.
    Please use plain text.
    Valued Contributor
    mortel09
    04-23-2012 06:35 AM in reply to: tony.ridley
    we are not supposed to use spreader bars, but we have added a support in one of the corner were we have cross checked RX, RY and RZ. This worked with the instabilty in node 52 :smileywink:
    Valued Contributor
    Rafacascudo
    04-23-2012 02:42 PM in reply to: mortel09
    Mortel09 ,No instabilities on your original model if you use the multi-threaded solver.
    Valued Contributor
    mortel09
    04-24-2012 12:53 AM in reply to: Rafacascudo
    the multi-threaded solver? I added a support in on of the corner so hold the rotation (RX, RY and RZ), will this be wrong to do?
    Valued Mentor
    tony.ridley
    04-24-2012 01:38 AM in reply to: mortel09
    My opinion is that if you have an instability in a model, using multi threaded to avoid it is un-conservative and not recommended.  The model should run fine on automatic before switching to multi thread.
    Product Support
    04-24-2012 01:55 AM in reply to: tony.ridley
    Multithreaded solver may not report instabilities that's why it is recommended to find all model instabilities (esspecially of type 1 and 2) using different solvers.
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Valued Contributor
    mortel09
    04-24-2012 02:02 AM in reply to: RG_Adsk
    Iam not sure what to do, I attached the file, when you hit calculations you get a warning of instability in node 52. What should i do?
    Valued Mentor
    tony.ridley
    04-24-2012 02:08 AM in reply to: mortel09
    it's type 3, so may just be large differernce in stiffness.
    Valued Contributor
    mortel09
    04-24-2012 02:11 AM in reply to: tony.ridley
    Okei, thanks alot guys. The both of you have been really helpfull. I appreciate your help.
    Product Support
    Artur.Kosakowski
    04-24-2012 02:58 AM in reply to: mortel09
    Please check the displacements and rotations for case 1 (self-weight) before ignoring the reported instability.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
