• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    issue with supports not falling within mesh
    213 Views, 5 Replies
    09-28-2012 04:34 AM
    Hi
    I am hoping you might be able to work out why my supports arent recognised within mesh/plates?
    Roberto
    Please use plain text.
    Product Support
    Re: issue with supports not falling within mesh
    09-28-2012 06:57 AM in reply to: robmirgga
    Change structure type back to shell and correct Z coordinates.
    Z should be = 0 (esspecially before changintype onto PLate)
    Z.jpgg structure
    Rafal Gaweda
    Product Support
    10-01-2012 09:12 AM in reply to: RG_Adsk
    Rafal
    The only table which I can visualise nodes on is the following:
    Having changed panels to RC shell, should I be able to visualise the Z coordinate also? Is there another mode I should be visualising the nodes?
    Roberto
    Product Support
    10-02-2012 12:14 AM in reply to: robmirgga
    Movie: http://screencast.com/t/DAnUcpKIC6
    Rafal Gaweda
    Product Support
    10-02-2012 01:38 AM in reply to: RG_Adsk
    Thank you very much for your help
    Product Support
    10-02-2012 01:39 AM in reply to: robmirgga
    BTW correct also panel Z coordinate in case of remeshing model.
    Rafal Gaweda
    Product Support
