• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Active Member
    Accepted Solution
    is the unbalanced moment effect considered in robot shear stress values ?
    178 Views, 6 Replies
    12-31-2012 05:13 AM
    thnx in advance
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: is the unbalanced moment effect considered in robot shear stress values ?
    01-02-2013 12:11 AM in reply to: adnan_0
    If you mean punching verification (RC Slab Provided Reinforcement) then yes, it is considered.
    If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Active Member
    01-03-2013 03:23 AM in reply to: Artur.Kosakowski
    no i mean in reading stress 1-2 in maps . is the values obtained take in consideration the unbalanced moment effect on  shear stress .
    Product Support
    Artur.Kosakowski
    01-03-2013 04:17 AM in reply to: adnan_0
    This is the shear in the plane of a panel rather than in the out of the panel plane direction. This stress can be caused by in plane shear force Nxy and twisting moment Mxy.  I'm sorry but I don't understand what effect exactly you mean. Could you give us more detailed description please?
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Active Member
    01-03-2013 04:31 AM in reply to: Artur.Kosakowski
    i think you answered me in indirect way .. so this stress result is the combination of  shear force Nxy and twisting moment Mxy.
    if we agree on this i will accept as an answer unless u want further detailed descreption to help  others i dont mind explaining ..
    Product Support
    Artur.Kosakowski
    01-03-2013 05:13 AM in reply to: adnan_0
    Correct :smileyhappy:
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Active Member
    01-03-2013 05:46 AM in reply to: Artur.Kosakowski
    thanks a lot for your time .. i appriciate your help
