• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Valued Contributor
    Jorgew09
    instability type 3 RX direction
    544 Views, 7 Replies
    03-09-2012 05:23 AM
    When I calculate my modell i get the following error: instability of type 3 in RX direction
    I have looked at the node but everything seems to be correct. I the releases box I have tried to tick off RX, but that did not help.
    Please use plain text.
    Product Support
    Re: instability type 3 RX direction
    03-09-2012 06:05 AM in reply to: Jorgew09
    Open calculatin Report , find there Max min values on stiffeness matrix diagonal and write here these two values.
    Rafal Gaweda
    Product Support
    Valued Contributor
    Jorgew09
    03-09-2012 06:31 AM in reply to: RG_Adsk
    Min/Max after decomposition:    7,463808e+006         6,847539e+019
    precision: 1
    Product Support
    03-09-2012 07:04 AM in reply to: Jorgew09
    if the difference between these values is greater than 1e11 \ 1e12 program reports instability number 3.
    It is related to big differences in stiffenes of elements for example very short elements exist in model = some inaccuracies.
    You can check it this way: on dummy model select everything, make intersection, then open Bars table on View tab. Find shortests bars. Then locate nodes \ places on original model and correct location of nodes.
    If it is not the case. Send me model. You already know how.
    Rafal Gaweda
    Product Support
    Valued Contributor
    Jorgew09
    03-09-2012 07:15 AM in reply to: RG_Adsk
    I don't understand how to do what you told me to do
    Valued Contributor
    Jorgew09
    03-09-2012 07:28 AM in reply to: Jorgew09
    I'm sending the file:smileyhappy:
    Product Support
    03-09-2012 07:33 AM in reply to: Jorgew09
    Example below
    If not - send me the file.
    Rafal Gaweda
    Product Support
    Product Support
    03-09-2012 07:54 AM in reply to: RG_Adsk
    Inacurracies in your model:
    Rafal Gaweda
    Product Support
