• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Active Member
    foundation design
    220 Views, 5 Replies
    11-09-2012 02:27 AM
    Hello, can i design the foundation with only the stress presiometric allowable value because i dont have all the soil caractristcs.
    so i have to delet the soil type (clay , sand ....) but i cant do that.
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: foundation design
    11-09-2012 02:39 AM in reply to: amirdj.gc
    Type the value of the allowable stress rather than use the analytical method.
    Artur Kosakowski
    Support Specialist
    Product Support
    Active Member
    11-09-2012 03:24 AM in reply to: Artur.Kosakowski
    thank you for the explanation but when i do these steps i can see in the foundation note that the soil type is included as you can see in the picture,
    Product Support
    Artur.Kosakowski
    11-09-2012 03:39 AM in reply to: amirdj.gc
    For the settings as on my picture the marked value will be used regardless of the soil profile you have defined in the Soils dialog.
    Artur Kosakowski
    Support Specialist
    Product Support
    Active Member
    11-09-2012 04:16 AM in reply to: Artur.Kosakowski
    i know that the value of the stress pressiometric is used but when i change the soil type the results change, why that
    Product Support
    Artur.Kosakowski
    11-09-2012 05:52 AM in reply to: amirdj.gc
    I'm not sure if I understand you correctly. The stress limit in the soil should not change but the load due to the change of soil weight can.
    Artur Kosakowski
    Support Specialist
    Product Support
