• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Distinguished Contributor
    factor of safety for shear in RC-Columns
    182 Views, 4 Replies
    12-24-2012 11:48 PM
    Dear Sirs
    Could I get advice for the following inquiries :
    - Why does the safety factor for shear in columns is very high when I use only external stirrup ?
    - Why does the safety factor for shear in column with internal stirrup is less than that of the column without internal stirrup ?
    Please , Could you take a look for attached captures and file.
    Note : If you use any capture for explanation . Kindly send it as attached.
    Thanks in advance
    Refaat
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: factor of safety for shear in RC-Columns
    12-27-2012 12:09 AM in reply to: refaat
    I can't see such problem. Could you send me the file where you have the 'middle' stirrups defined?
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    12-27-2012 02:15 AM in reply to: Artur.Kosakowski
    Dear Artur
    Attached is the required file . could you take a look to it?
    Thanks in advance
    Refaat
    Product Support
    Artur.Kosakowski
    12-27-2012 02:27 AM in reply to: refaat
    What was the way you generated this reinforcement distribution in the column?
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    12-27-2012 04:00 AM in reply to: Artur.Kosakowski
    Dear Artur
    I used "Typical Reinforcement" option
    Refaat
