execution problem no 3306
Hello, i've been using RSAP 2012 and when i try to calculate model i get this message
do you have any ideas?
thanks
Artur.Kosakowski
Autodesk Support
Autodesk Support
Do you have the file saved on the network drive (lost of the connection during calculations) or is your available disk space low? For the prior try to copy the file to the local drive and then calculate it again.
Artur Kosakowski
hi,
i copied it to the local driver and now it works!
thank you,
