Autodesk Robot Structural Analysis
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
dead weight with a coefficien t
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
How can I create this load with Robot API ?
I would like the load of dead weight with a coefficient.
10:charge verticale poids propre 1A5 Partie de la structure -Z Coef=0.20 MEMO :
I think it's not possible with text file.
Can you give me the macro for VB please ?
Re: dead weight with a coefficien t
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Try the following one please:
Dim ra As New RobotOM.RobotApplication
Dim sc As RobotOM.RobotSimpleCase
Dim rc As RobotOM.RobotLoadRecordDead
sc = ra.Project.Structure.Cases.CreateSimple(10, "charge verticale", RobotOM.IRobotCaseNature.I_CN_PERMANENT, RobotOM.IRobotCaseAnalizeType.I_CAT_STATIC_LINEAR)
rc = sc.Records.Get(sc.Records.[New](RobotOM.IRobotLoad
rc.SetValue(RobotOM.IRobotDeadRecordValues.I_DRV_C
rc.SetValue(RobotOM.IRobotDeadRecordValues.I_DRV_E
rc.SetValue(RobotOM.IRobotDeadRecordValues.I_DRV_Z
rc.Objects.FromText("1 2 3 4 5")
Artur Kosakowski
Support Specialist
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I_DRV_COEFF doesn't exist. Is it new ? I don't have Robot Pro 2012, I have Robot Pro 2011.
My macro
Sub poids_propre_coef()
Dim cas As RobotOM.RobotSimpleCase
Set cas = Loads.Get(nocasdecharge)
' sc = ra.Project.Structure.Cases.CreateSimple(10, "charge verticale", RobotOM.IRobotCaseNature.I_CN_PERMANENT, RobotOM.IRobotCaseAnalizeType.I_CAT_STATIC_LINEAR)
rc = sc.Records.Get(cas.Records.[New](RobotOM.IRobotLoa dRecordType.I_LRT_DEAD))
If coefx = 0 Then
If coefz = 0 Then
MsgBox "Pas de coef pour la charge de poids propre!", vbOKOnly + vbExclamation, "INVALID FOLDER"
Exit Sub
Else
' rc.SetValue(RobotOM.IRobotDeadRecordValues.I_DRV_C OEFF, coefz) = True
rc.SetValue(RobotOM.IRobotDeadRecordValues.I_DRV_Z , DirZ) = True
End If
Else
' rc.SetValue(RobotOM.IRobotDeadRecordValues.I_DRV_C OEFF, coefx) = True
rc.SetValue(RobotOM.IRobotDeadRecordValues.I_DRV_X , dirx) = True
End If
rc.SetValue(RobotOM.IRobotDeadRecordValues.I_DRV_E NTIRE_STRUCTURE, 0) = True
rc.Objects.FromText ("Tous")
End sub
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
replace
rc.SetValue(RobotOM.IRobotDeadRecordValues.I_DRV_COEFF, coefz)
by
rc.SetValue(3, coefz)
Rafal Gaweda
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
This command doesn't work.
rc1.Objects.FromText ("1 2 3 4 5")
Dim Loads As RobotCaseServer
Set Loads = robapp.Project.Structure.Cases
' Dim ra As New RobotOM.RobotApplication
Dim cas As RobotSimpleCase
Dim rc As RobotLoadRecordMngr
Dim rc1 As RobotLoadRecordDead
' rc = cas.Records.Get(cas.Records.New(IRobotLoadRecordTy pe.I_LRT_DEAD))
Set rc = cas.Records
i = rc.New(I_LRT_DEAD)
Set rc1 = rc.Get(i)
If coefx = 0 Then
If coefz = 0 Then
Exit Sub
Else
rc1.SetValue 3, coefz
rc1.SetValue I_DRV_ENTIRE_STRUCTURE, 0
rc1.SetValue I_DRV_Z, DirZ
' rc1.Objects.FromText ("1 2 3 4 5")
End If
Else
rc1.SetValue 3, coefx
rc1.SetValue I_DRV_X, dirx
End If
Set rc = Nothing
Set rc1 = Nothing
Set cas = Nothing
End Sub
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Try this:
rc1.Objects.FromText "1 2 3 4"
Rafal Gaweda
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Ok but why this command doesn't work ?
rc1.Objects.FromText "tous"
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
This command should work in Frencha language version of ARSA
try this code for french and english:
rc1.Objects.AddText "tous"
rc1.Objects.AddText "all"
Rafal Gaweda
Product Support
