• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    stroxy
    column Design Loads
    279 Views, 7 Replies
    12-09-2011 12:39 AM
    In the column note for "provided reinforcement"I only see my static loads and no seismic (ACC) load cases, although they have been defined and used in the analysis and calculation of required reinforcement.
    Please use plain text.
    Product Support
    Re: column Design Loads
    12-09-2011 12:54 AM in reply to: stroxy
    It should be like that:
    BTW which code?
    Rafal Gaweda
    Product Support
    stroxy
    12-09-2011 01:31 AM in reply to: RG_Adsk
    I delect the seismic loads in the Parameters dialog alright, but they don't show up in the RC model.
    Product Support
    12-09-2011 01:40 AM in reply to: stroxy
    Which robot version do you use?
    Which RC code?
    Any chance to upload the file?
    Rafal Gaweda
    Product Support
    stroxy
    12-09-2011 01:47 AM in reply to: RG_Adsk
    RSAP 2012.
    The file size is huge over 100MB
    Codes attached
    stroxy
    12-09-2011 02:52 AM in reply to: RG_Adsk
    Is there a way to email the file to you?
    Product Support
    12-09-2011 03:13 AM in reply to: stroxy
    yes.
    Check Private Message
    Rafal Gaweda
    Product Support
    Product Support
    12-21-2011 12:58 AM in reply to: RG_Adsk
    My poor memory ;-)
    This is the cause :
    Rafal Gaweda
    Product Support
