• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Valued Mentor
    AJA14
    can't add thermal loads
    694 Views, 2 Replies
    11-29-2011 01:17 AM
    I am trying to add thermal loads for bar elements. The problem is I can't find temperature or thermal loads in the new load type dialog. I've done it before but this time I can't locate it. If I open the load table and use the cell list, I can locate thermal loads. I even tried switching to different design and loading codes. Nothing happened. Any ideas.
    Ali Al-Hammoud
    Structural Design Engineer
    MZ & Partners Engineering Consultancy
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: can't add thermal loads
    11-29-2011 01:42 AM in reply to: AJA14
    I'd say you look at the wrong dialog :smileyhappy:
    If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Product Support
    11-29-2011 01:45 AM in reply to: AJA14
    Natures displayed there are taken from Code Combinations settings (active code).
    Go to Job Preferences, check Code Combinations
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
