• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Valued Mentor
    AJA14
    cable design
    486 Views, 1 Replies
    11-14-2011 12:37 AM
    In analysis of cables via robot, a pretension value has to be inserted and then iterations have to be made. I was wondering if there was a way to predetermine a good judgement for the pretension to be used for the cable which eliminates the need for doing many iterations. This may not be a pure robot question but I would appreciate the help nevertheless.
    Ali Al-Hammoud
    Structural Design Engineer
    MZ & Partners Engineering Consultancy
    Please use plain text.
    Product Support
    Re: cable design
    11-15-2011 12:38 AM in reply to: AJA14
    For preliminary analysis of models containing many cables it is much more efficient to define cables not by pretension but by elongation or length:
    In such case when specifying for instance zero relative elengation the unloaded cable length equal to the distance of end nodes will be used. For instance +0.01 relative elongation corresponds to unloaded cable length 1 percent longer than the distance of end nodes.
    In case of defining cables by pre-tension it is sometimes very difficult to predict what unloaded cable lengths may be necessary to obtain it and moreover there is a risk that equilibrium and convergence is not possible with reasonable lengths of cables. See:
    http://docs.autodesk.com/RSA/2012/ENU/filesROBOT/GUID-DCDD6D6E-D1BA-4535-9A21-AA28C9277CF-243.htm
    If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
    Best regards,
    Pawel Pulak
    Support Specialist
    Product Support
