• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Distinguished Contributor
    faisal.aaouatif
    beams Reinforcement module
    172 Views, 4 Replies
    08-08-2012 03:03 AM
    Hi all ,
    after calculating a building structure in RSA2013, i export beams to their reinforcement module, and i wanted to modify length of some of them ( few cm  to be in accordance with layout ) without going back to RSA and recalculate the hole structure, but the i found that the beam length textbutton is grayed.
    Is there anyway to do it ( it seems to be possible with cbs ...) other than calculating beams reinforcement and exporting them to structural detailing for adjustement ( heavy procedure ...)
    Thank you
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: beams Reinforcement module
    08-08-2012 03:24 AM in reply to: faisal.aaouatif
    It is possible to edit geometry of a beam but you have to select the span you want to modify first. See the attached picture.
    Artur Kosakowski
    Support Specialist
    Product Support
    faisal.aaouatif
    08-08-2012 05:40 AM in reply to: Artur.Kosakowski
    Great . Thank you very much
    Another question please ; how can recuperate element names ( beams , columns ) defined in RSA ( for ex Barre n°176 named Beam-01...) in reinforcement module automatically ?
    Product Support
    Artur.Kosakowski
    08-08-2012 06:12 AM in reply to: faisal.aaouatif
    No, this is not possible. You have to edit names manually.
    Artur Kosakowski
    Support Specialist
    Product Support
    faisal.aaouatif
    08-08-2012 06:48 AM in reply to: Artur.Kosakowski
    Ok Thank you.
    May be on a closer update , it would be helpful ...
