• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Active Member
    john.sodergran
    Accepted Solution
    automatically generated snow / wind loads according to EC1
    852 Views, 6 Replies
    02-24-2012 04:26 AM
    Is there any function in robot 2012 that automatically generates snow / wind loads to an existing frame ? or
    Can you use the frame generator for making snow / wind loads (all different zones) on an existing frame ?
    Please use plain text.
    Product Support
    Re: automatically generated snow / wind loads according to EC1
    02-24-2012 04:41 AM in reply to: john.sodergran
    It depends on national code set in job preferences. For some only 2D, for some 3D also.
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Active Member
    john.sodergran
    02-24-2012 05:23 AM in reply to: RG_Adsk
    if the wind and snow 2D / 3D field cannot be chosen, does this mean that it cannot be used with the national code currently set ? (Finland)
    Product Support
    02-24-2012 05:35 AM in reply to: john.sodergran
    John
    Yes, but select French code, then specify "your" pressures and check generated loads.
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Member
    olivierkst
    05-10-2012 09:58 AM in reply to: RG_Adsk
    If I understand well, wind and snow loads according to the Eurocode cannot be generated automatically in RSA 2012. at least for 3D structures.
    Do you happen to know whether it will be implemented in RSA 2013?
    Thanks for your answer
    Olivier
    Product Support
    Artur.Kosakowski
    05-10-2012 11:45 PM in reply to: olivierkst
    If you mean arbitrary shape of 3D structure then this is not possible (you can use cladding load instead) however this is possible for a  warehouse structure types that are based on number of identical frames (you enter the geometry of a single frame in a 2D Frame model and then you provide spacing among the frames creating a 3D frame model).
    As we have already mentioned in couple of the topic due to the company policy we are not able to provide any information about the development plans on this forum. They have to be officially announced by Autodesk first.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Member
    olivierkst
    05-11-2012 01:02 AM in reply to: john.sodergran
    Thanks for your quick and clear answer.
    Olivier
