Autodesk Robot Structural Analysis
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Wish list RC-Structu ral elements
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Dear Colleagues
I hope the following options to be added to wish list:
- (RC-Walls)
- (Typical Reinforcement option as RC - Beams &columns).
- Reinforcement Generation without Edge reinforcement using ACI318-08M.
-(Continuous Footing)
- (RC-Beams)
- ( Possibility to use layers for top reinforcement and bottom reinforcement in typical reinforcement option).
-(RC-Columns)
- (Possibility to use bundle system and spiral stirrups in typical reinforcement option).
- Seismic (Equivalent lateral force method -ASCE7-10/IBC2009)
- (Possibility to select and control the percentage of load type which is used to calculate the seismic forces because some codes such as(ASCE7-10)doesn't consider live loads only in the storage areas (only 25%)).
Very Useful.
Refaat
Re: Wish list RC-Structu ral elements
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- (RC-Walls)
- (RC-Beams)
-(RC-Columns)
I have added them to the wish list. Mind that you can generate reinforcement in bundles.
Available.
Would it be just enough to define seismic combination with 0.25 load factor for live loads?
Artur Kosakowski
Support Specialist
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Dear Artur
Happy new year
Thanks a lot for your response but I would like to clarify the following points :
RC-Columns
Bundles system : I prefer to be implemented inside the " Typical Reinforcement Option " if possible .
I mean " The effective seismic weight " which was based to generate the seismic forces on structures .(Please , take a look to attached capture from "ASCE7-10")
Does ROBOT consider the code requirements(No live loads on floors and only 25% of it in the storage area ) internally when the effective seismic weight is calculated? if "No" is there any possibility to add such option for ( Equivalent lateral force method) like " Load to mass conversion option"?
With Best Regards
Refaat
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
RC-Columns
Added to the wish list.
You can use loads to mass conversion for this type of analysis too. If you create such 'storage area' live loads and then convert them into masses with 0.25 factor then this definition will be taken into account. No other live loads are included unless they are also converted into masses.
Artur Kosakowski
Support Specialist
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Dear Artur
Supper answer
Please , for " add mass to " shall I use " Dynamic mass or Global mass " for (Equivalent lateral force method )
Many Thanks
Refaat
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Both will work but it is better to use the dynamic one. The other is for inertia forces and will 'influence' display of loads for simple load cases.
Artur Kosakowski
Support Specialist
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Dear Artur
Wonderful , Thanks a lot
Refaat
