Autodesk Robot Structural Analysis
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Re: Wind Load
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Are the loads transfered from CBS to Robot?
Gustavo
Re: Wind Load
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You can export models (with loads) from CBS to Robot or calcalculate them in CBS using Robot or its calculation engine.
Artur Kosakowski
Support Specialist
Product Support
Re: Wind Load
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks to everybody. I defined the wind loads manually on claddings as Artur suggested. But still there are a few problems.
1. If there are shear walls in some parts of a face, should I need to draw cladding over the shear walls also or I can stop at the beginning edge of shear wall?
2. After I defined all the wind loads, it takes too much time to calculate. Before applying wind load it took 5.5 minutes, but now it takes 20 minutes. And most of this time is consumed in "applying loads" stage. Is it normal, or there is any problem?
I mean, upto now I only defined loads for each cases separately. When I combine them, then it will take even more time.
Re: Wind Load
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Toah_mh
as I said before, I use NV code and it doesn't take to much time to calculate. Just give a try.
Gustavo
Re: Wind Load
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi, can you please give a short instruction how I can use it? I don't have any idea?
