• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Active Member
    Accepted Solution
    Warping Constant using AISC member
    97 Views, 2 Replies
    02-06-2013 03:15 PM
    AISC members have a warping constant (Iom or Cw) = 0 using the member from the AISC database. (see below).
    But when I use this member with the CSA S16-09 design code, I get results that assign a value to Cw (see below)
    Where is ROBOT getting the value of Cw?
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: Warping Constant using AISC member
    02-07-2013 12:43 AM in reply to: CameronEC
    It is calculated 'inside' the steel design module either based on formulas form the selected design code or the general ones for the declared section type. E.g.
    If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Active Contributor
    Dirgs
    02-07-2013 01:58 AM in reply to: Artur.Kosakowski
    Artur,
    This answer is also useful for my last post on Lateral Bucklyng of Tapered Section.
    :smileyhappy:
