Warping Constant using AISC member
CameronEC
Message 1 of 9
CameronEC
AISC members have a warping constant (Iom or Cw) = 0 using the member from the AISC database. (see below).
But when I use this member with the CSA S16-09 design code, I get results that assign a value to Cw (see below)
Where is ROBOT getting the value of Cw?
Replies (8)
Message 2 of 9
Artur.Kosakowski
Autodesk Support
Autodesk Support
It is calculated 'inside' the steel design module either based on formulas form the selected design code or the general ones for the declared section type. E.g.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Message 3 of 9
Artur,
This answer is also useful for my last post on Lateral Bucklyng of Tapered Section.
Smiley Happy
Message 4 of 9
Hello!
Is there an calculation formula how to calculate Iw for rectalngular cross section? I find for all cross sections except rectangular.
Message 5 of 9
Artur.Kosakowski
Autodesk Support
Autodesk Support
  alpha=b-t
  beta=h-t
  Iw=alpha*alpha*beta*beta*(alpha-beta)*(alpha-beta)*t/(24.0*(alpha+beta))
Artur Kosakowski
Message 6 of 9
Artur.Kosakowski, Would you please provide the reference of that table? Thanks.
Message 7 of 9
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
It is from the Polish steel design code.
Artur Kosakowski
Message 8 of 9
Thank you, @Artur.Kosakowski !
Message 9 of 9
I was trying to get a consistent method to calculate the warping constant (Cw) of closed sections and I wanted to compare it with an analytic formula. Could you tell me what is the source of the one you published here? It's easy to find warping constant formulas for open sections, not so much for closed ones. Thanks in advance.
