• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Valued Contributor
    pevelor
    Warning: Element not assigned to any story
    195 Views, 2 Replies
    03-05-2012 11:17 PM
    Hi
    After running calculations, I get an error telling me that some of my elements are not assigned to any story.
    My questions are,
    - Do I need to correct this or can I disregard the warning?
    - What are the consequenses of disregarding it?
    - How do I easely choose the correct story for each element?
    In advance, thanks.
    Peder
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: Warning: Element not assigned to any story
    03-06-2012 12:18 AM in reply to: pevelor
    If you  want to run seismic analysis and check results for stories then probably no; otherwise you can
    See above.
    You can use one of the Assign options shown on the attached picture.
    Artur Kosakowski
    Support Specialist
    Product Support
    Valued Contributor
    pevelor
    03-06-2012 12:40 AM in reply to: Artur.Kosakowski
    Thank you
