View Tension / Compression Only Members
Message 1 of 10
I'm in the process of checking some ROBOT models. These models may or may not include tension only or conpression only members.
Is there a way to show these members in the view window? or another way to check whether they have been used?
I have found a way to view 'truss' members (Selection -> Bars -> Advanced -> Truss), this highlights the 'truss' members. Is there a way to do the same for 'tension only' or 'compression only' members?
I have tried the help documentation and seaching here, but haven't had any luck yet.
Thank you for your help.
Stuart
Replies (9)
Message 2 of 10
Artur.Kosakowski
Autodesk Support
Autodesk Support
See the attached picture.
Artur Kosakowski
Message 3 of 10
Great! Thanks Artur
Message 4 of 10
Jummybear
One question about truss and compression/tension bars: when i use them it seems that no bending moment appears in the current bar, but what are the terms of the ends in such bar? Does it use releases on the ends automatically?
Message 5 of 10
Artur.Kosakowski
Autodesk Support
Autodesk Support
No, this is a special typ bar element with no rotational d.o.fs.
If you use releases on a standard bar you may have bending along its length despite the fact that there is no bending at its ends.
Artur Kosakowski
Message 6 of 10
Jummybear
So in some cases i need to use truss or compression/tension bar + releases at the ends?
Message 7 of 10
Artur.Kosakowski
Autodesk Support
Autodesk Support
No, as the truss members have got no rotational d.o.fs you are not allowed to define releases for moments.
On the other hand you can define standard bar with such releases (it will act as a truss bar provided no load along its length is defined) and add unidirectional release along its length (tension/compression only action).
Artur Kosakowski
Message 8 of 10
Hi, I tried to do that but when I chosse: selecstion>bars>advanced there is no more choises. How can I define some members as a tension members?
Thanks for help
Message 9 of 10
Artur.Kosakowski
Autodesk Support
Autodesk Support
Artur Kosakowski
Message 10 of 10
Thanks Smiley Happy
