Autodesk Robot Structural Analysis
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
View Tension / Compressio n Only Members
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I'm in the process of checking some ROBOT models. These models may or may not include tension only or conpression only members.
Is there a way to show these members in the view window? or another way to check whether they have been used?
I have found a way to view 'truss' members (Selection -> Bars -> Advanced -> Truss), this highlights the 'truss' members. Is there a way to do the same for 'tension only' or 'compression only' members?
I have tried the help documentation and seaching here, but haven't had any luck yet.
Thank you for your help.
Stuart
Re: View Tension / Compressio n Only Members
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
See the attached picture.
Artur Kosakowski
Support Specialist
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Great! Thanks Artur
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
One question about truss and compression/tension bars: when i use them it seems that no bending moment appears in the current bar, but what are the terms of the ends in such bar? Does it use releases on the ends automatically?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
No, this is a special typ bar element with no rotational d.o.fs.
If you use releases on a standard bar you may have bending along its length despite the fact that there is no bending at its ends.
Artur Kosakowski
Support Specialist
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
So in some cases i need to use truss or compression/tension bar + releases at the ends?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
No, as the truss members have got no rotational d.o.fs you are not allowed to define releases for moments.
On the other hand you can define standard bar with such releases (it will act as a truss bar provided no load along its length is defined) and add unidirectional release along its length (tension/compression only action).
Artur Kosakowski
Support Specialist
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi, I tried to do that but when I chosse: selecstion>bars>advanced there is no more choises. How can I define some members as a tension members?
Thanks for help
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Artur Kosakowski
Support Specialist
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks ![]()
