• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    View Tension / Compression Only Members
    478 Views, 9 Replies
    10-22-2012 09:00 AM
    I'm in the process of checking some ROBOT models. These models may or may not include tension only or conpression only members.
    Is there a way to show these members in the view window? or another way to check whether they have been used?
    I have found a way to view 'truss' members (Selection -> Bars -> Advanced -> Truss), this highlights the 'truss' members. Is there a way to do the same for 'tension only' or 'compression only' members?
    I have tried the help documentation and seaching here, but haven't had any luck yet.
    Thank you for your help.
    Stuart
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: View Tension / Compression Only Members
    10-23-2012 12:01 AM in reply to: StuartRogers
    See the attached picture.
    Artur Kosakowski
    Support Specialist
    Product Support
    10-23-2012 12:27 AM in reply to: Artur.Kosakowski
    Great! Thanks Artur
    Valued Contributor
    ilja.jevglevski
    02-05-2013 12:24 AM in reply to: Artur.Kosakowski
    One question about truss and compression/tension bars: when i use them it seems that no bending moment appears in the current bar, but what are the terms of the ends in such bar? Does it use releases on the ends automatically?
    Product Support
    Artur.Kosakowski
    02-05-2013 12:41 AM in reply to: ilja.jevglevski
    No, this is a special typ bar element with no rotational d.o.fs.
    If you use releases on a standard bar you may have bending along its length despite the fact that there is no bending at its ends.
    Artur Kosakowski
    Support Specialist
    Product Support
    Valued Contributor
    ilja.jevglevski
    02-05-2013 12:46 AM in reply to: Artur.Kosakowski
    So in some cases i need to use truss or compression/tension bar + releases at the ends?
    Product Support
    Artur.Kosakowski
    02-05-2013 02:57 AM in reply to: ilja.jevglevski
    No, as the truss members have got no rotational d.o.fs you are not allowed to define releases for moments.
    On the other hand you can define standard bar with such releases (it will act as a truss bar provided no load along its length is defined) and add unidirectional release along its length (tension/compression only action).
    Artur Kosakowski
    Support Specialist
    Product Support
    Member
    02-26-2013 03:19 AM in reply to: Artur.Kosakowski
    Hi, I tried to do that but when I chosse: selecstion>bars>advanced there is no more choises. How can I define some members as a tension members?
    Thanks for help
    Product Support
    Artur.Kosakowski
    02-26-2013 03:29 AM in reply to: 85778RSAPRO_2012_0F
    Artur Kosakowski
    Support Specialist
    Product Support
    Member
    02-26-2013 03:41 AM in reply to: Artur.Kosakowski
    Thanks :smileyhappy:
