• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Moderator
    Romanich
    Very slow сopying of elements
    193 Views, 8 Replies
    07-06-2012 02:06 AM
    how we can speed up copy/move elemenets in Robot model? I need to copy set of panels and lines from column to column and it's very very slow. Maybe I didn't know some trick :smileywink:
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: Very slow сopying of elements
    07-06-2012 02:14 AM in reply to: Romanich
    Try to switch undo off. You may need to restart Robot.
    Artur Kosakowski
    Support Specialist
    Product Support
    Moderator
    Romanich
    07-06-2012 02:22 AM in reply to: Artur.Kosakowski
    Artur, nothing happens...
    Product Support
    Artur.Kosakowski
    07-09-2012 05:30 AM in reply to: Romanich
    Try to switch off display of interiors and thicknesses on ALL VIEWERS (mind that for the building model the viewer has got TWO tabs) including the additional ones you opened.
    Artur Kosakowski
    Support Specialist
    Product Support
    Moderator
    Romanich
    07-09-2012 05:37 AM in reply to: Artur.Kosakowski
    Artur, this didn't help me. Also I'm tried to switch off selection synchronization between views, but this didn't help too.
    Product Support
    Artur.Kosakowski
    07-09-2012 06:40 AM in reply to: Romanich
    Please make sure you switched off display of these attributes on ALL viewers. I have tested this on my computer before posting the answer to check it works. Please send me the screen capture that shows how your screen (in Robot) looks like just before trying to run copying.
    Artur Kosakowski
    Support Specialist
    Product Support
    Moderator
    Romanich
    07-09-2012 06:54 AM in reply to: Artur.Kosakowski
    This is a screen:
    On a Plan view settings the same.
    Please, try to copy elements  8309to8336  for example.
    Also, when I'm working in English language version of Robot, after each save Robot show this dialog:
    Product Support
    Artur.Kosakowski
    07-10-2012 02:31 AM in reply to: Romanich
    See the movie
    http://screencast.com/t/5sXngzMdzO
    Before opening the Display dialog I pressed the default display button to make sure that I have the control over the settings you made in the file.
    Artur Kosakowski
    Support Specialist
    Product Support
    Moderator
    Romanich
    07-10-2012 03:05 AM in reply to: Artur.Kosakowski
    Thank you, Artur! Last trick has decided my issue.
