• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Valued Contributor
    Values of the diagrams (Mx,My,Mz)
    312 Views, 4 Replies
    08-13-2012 04:31 AM
    Please tell me why I can't see the values of these moments in the end and at the beginning of the rods? (for example for the rod 2084) Thanks in advance 1.jpg
    Please use plain text.
    Valued Mentor
    tony.ridley
    Re: Values of the diagrams (Mx,My,Mz)
    08-13-2012 04:46 AM in reply to: Ievgen
    You probably have "global extremes" checked.  Change to "all"
    (under results--------->diagrams for bars-------->parameters)
    Valued Contributor
    08-13-2012 05:01 AM in reply to: tony.ridley
    What do I do wrong?
    Product Support
    Artur.Kosakowski
    08-13-2012 05:09 AM in reply to: Ievgen
    Please use maps on bars descriptions instead. The description for diagrams show max and min values only.
    Artur Kosakowski
    Support Specialist
    Product Support
    Valued Mentor
    tony.ridley
    08-13-2012 05:16 AM in reply to: Artur.Kosakowski
    Yes this is true.
    But only when the element has "symetrical" internal forces, such as in the original picture posted.  Of course if the loading is constant the end moment will be the same at both ends,
    If the force in the bar is not symetrical, then my suggestion works:smileyvery-happy:.
