• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Product Support
    Artur.Kosakowski
    Re: VERIFICATION GROUP MEMBER
    09-06-2012 03:27 AM in reply to: Artur.Kosakowski
    One more question: have you checked what happens if you use dot as a separator rather than comma?
    Check if there is any difference if you use comma (0,2) or dot (0.2)
    Artur Kosakowski
    Support Specialist
    Product Support
    Please use plain text.
    Valued Contributor
    StefanoPasquini6790
    09-06-2012 09:05 AM in reply to: Artur.Kosakowski
    Hi Artur,
     I tried every way: graphical, dot or comma...
    many time ago, i had a similar problem with the filter on table, and i resolved clearing the cfgusr folder. Unfortunely this operation remove EVERY personalization.
    Can you specify the file included in the cfgusr folder to remove? This can be a speey way to resolve this issue.
    What can be the cause of this issue? I'd like to find the real cause for the future.
    thk a lot.
    Product Support
    Artur.Kosakowski
    09-07-2012 12:01 AM in reply to: StefanoPasquini6790
    I'm sorry but at this moment I don't know what the possible cause could be. It would be possible that your regional settings (settings of separators to be exact) of Windows may have some influence but in such case one of the two (comma or dot) as well as graphical settings should work. Please try to rename the CfgUsr folder and check if this makes any difference. Knowing this we can start to find out which particular file (setting) can cause this.
    Artur Kosakowski
    Support Specialist
    Product Support
