Autodesk Robot Structural Analysis
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Re: VBA loads
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
RG_Adsk wrote:Ok is it possible to do it automaticaly. Is there a file default to copy ?
So you already know where the database file is located.
Add database to job preferences as shown in previous post, then save preferences:
File named ...cov will be saved in path which can be checked in the field marked by green rectagle below
Then copy it to different computers to similar folder, besides copying database file.
when I generate a new model the data base is not the default one I want. I have to load the catalog by myself. That's why I have no moving loads on the slab. I have replaced the file DEFAULTS.cov in :
C:\Users\xxxx\AppData\Roaming\Autodesk\Autodesk Robot Structural Analysis 2012\CfgUsr
but it's not working.
Is that possible to load the catalog by default automatically ?
Re: VBA loads - API
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
mateaus wrote:I create a sub which define loads on a pannel but it's doesn't work.
Can you have a look ?
Public typecharge As String Public casdecharge As String Public valeurcharge As Double Public x_1 As Double Public y_1 As Double Public z_1 As Double Public x_2 As Double Public y_2 As Double Public z_2 As Double Public x_3 As Double Public y_3 As Double Public z_3 As Double Public x_4 As Double Public y_4 As Double Public z_4 As Double
Public Sub charges() 'trotoirs typecharge = I_CN_PERMANENT casdecharge = "Equipements" valeurcharge = 5.5 x_1 = 0.000 y_1 = 0.000 z_1 = 0.000 x_2 = 75.480 y_2 = 0.000 z_2 = 0.000 x_3 = 76.143 y_3 = 1.600 z_3 = 0.000 x_4 = 0.663 y_4 = 1.600 z_4 = 0.000 Call chargement_panneau_contour End Sub
Sub chargement_panneau_contour() Dim cas As RobotSimpleCase Dim recs As RobotLoadRecordMngr Dim rec_1 As RobotLoadRecordInContour Set cas = robapp.Project.Structure.Cases.CreateSimple(robapp.Project.Structure.Cases.FreeNumber, _ casdecharge, typecharge, I_CAT_STATIC_LINEAR) Set recs = cas.Records ' pression uniforme horizontale appliquée au contour ' définition des contours i = recs.New(I_LRT_IN_CONTOUR) ' création d'une nouvel enregistrement Set rec_1 = recs.Get(i) ' définition du plan de charge rec_1.Objects.FromText "1" rec_1.SetValue I_ICRV_PX1, 0 rec_1.SetValue I_ICRV_PY1, 0 rec_1.SetValue I_ICRV_PZ1, -valeurcharge rec_1.SetValue I_ICRV_PX2, 0# rec_1.SetValue I_ICRV_PY2, 0# rec_1.SetValue I_ICRV_PZ2, -valeurcharge rec_1.SetValue I_ICRV_PX3, 0# rec_1.SetValue I_ICRV_PY3, 0# rec_1.SetValue I_ICRV_PZ3, -valeurcharge ' sens de projection des efforts rec_1.SetValue I_ICRV_PROJECTION, 1 ' nombre de points composant le contour rec_1.SetValue I_ICRV_NPOINTS, 4 rec_1.SetValue I_ICRV_LOCAL, 0 ' définition des points sur le panneau rec_1.SetPoint 1, 0, 0, 0 rec_1.SetPoint 2, 1, 1, 0 rec_1.SetPoint 3, 1, 0, 0 rec_1.SetContourPoint 1, x_1, y_1, z_1 rec_1.SetContourPoint 2, x_2, y_2, z_2 rec_1.SetContourPoint 3, x_3, y_3, z_3 rec_1.SetContourPoint 4, x_4, y_4, z_4 rec_1.SetVector 0, 0, 1 Set recs = Nothing Set rec_1 = Nothing Set cas = Nothing End Sub
Is that possible to set value of coordinates of this contour
rec_1.SetContourPoint 4, x_4, y_4, z_4by something which import coordinates of nodes that exist already in the model like :
x_1 = x of point 1 in the model
Re: VBA loads - API
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
What does not work?
This is what I see running your code:
Rafal Gaweda
Product Support
Re: VBA loads - API
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have created points in the model. And I want to set the coordinates of the point of the model to the points of the macro.
For exemple :
You select point number 1
You import his coordonates
And you set the values in x1 y1 z1
Re: VBA loads - API
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Example attached
Rafal Gaweda
Product Support
