• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Product Support
    VBA Excel macro for any object geometry modifications (API)
    1912 Views, 11 Replies
    10-12-2011 05:31 AM
    Hi
    For those who might be interested I am attaching xls file with macro for objects geometry modifications.
    One button to import geometry (characteriscic points coordinates) of selected objects (lines, polylines, arc, circles, panels), second - to update their geometry basing on data in Excell.
    NOTE: modify only cells with coordinates.
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Please use plain text.
    Member
    Perhed
    Re: VBA Excel macro for any object geometry modifications
    10-12-2011 08:26 AM in reply to: RG_Adsk
    Hello!
    I tried your excel sheet, but it doesn´t recoginze that robot is open.
    How should i use the macro?
    /Per
    Product Support
    10-13-2011 12:06 AM in reply to: Perhed
    Hi
    Go to VBA Editor (Alt+F11), go to References, unmark Robot Object Modeler, close References window by pressing OK, open it again, select  Robot Object Modeler ver. 12.0., press OK
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Member
    Perhed
    10-14-2011 12:05 AM in reply to: RG_Adsk
    I´ve tried your solution on the problem, but it still gives the same error message.
    /Per
    Product Support
    10-14-2011 12:49 AM in reply to: Perhed
    Try:
    1. Run Excel as Administrator, run Robot as Administrator, then check macro
    2. Check \ set UAC :
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Member
    Perhed
    10-14-2011 01:18 AM in reply to: RG_Adsk
    This gives the same error.
    Product Support
    10-14-2011 01:30 AM in reply to: Perhed
    I need to ckeck it on your computer
    Please register this isseu as Service Request or give me your details in Private Message
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Product Support
    10-14-2011 04:15 AM in reply to: RG_Adsk
    In such case unregister ALL ROBOTS you have installed on your computer by command: path_to_robot.exe / unregserver
    eg:
    "C:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2011\System\Exe\robot.EXE" /unRegServer
    then
    register the one you want to use.
    eg:
    "C:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2012\System\Exe\robot.EXE" /RegServer
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Active Contributor
    RoboExploiter
    02-12-2012 05:52 PM in reply to: RG_Adsk
    I had the same problem which i managed to solve with the help of the structural support team:
    http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Robot-API-for-ARSA-2012-error-429/td-p/32153...
    A colleague of mine recently upgraded from ARSA 2011 to 2012, and our excel VBA API was unable to recognise that 2012 was open.  I tried to deregister both and register 2012 (with administration rights) with the method described in this post, but it didn't work.
    I remember last time this happened Structural Support and I worked through the registry looking for and deleting outdated ARSA 2011 entries... can you tell me what to look for, what to delete, and what to keep?
    Product Support
    09-28-2012 12:46 AM in reply to: RoboExploiter
    JUst to link some threads .
    Modified macro with rounding:
    http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Panel-contour-points-modification-API/td-p/3...
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
