• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Moderator
    Romanich
    Accepted Solution
    User reinforcing database and required reinforcment
    172 Views, 6 Replies
    07-12-2012 05:53 AM
    I made my own database of reinforcement bars and when used it I see this:
    As I know from SDK Kit, Robot uses method to obtain diameter from area of required reinforcement. So, question is - maybe uses of BarSize field data (or DiameterReal) will be correct than this one ?
    In provided reinforcement all correct.
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: User reinforcing database and required reinforcment
    07-13-2012 03:23 AM in reply to: Romanich
    I'm not sure if I understand you correctly. Is the objective to have 2f14.8 and 4f23.2 in the reinforcement table?
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Moderator
    Romanich
    07-13-2012 03:27 AM in reply to: Artur.Kosakowski
    No, objective is to have 2f16 and 4f25 in the reinforcement table.
    Moderator
    Romanich
    07-16-2012 01:53 AM in reply to: Artur.Kosakowski
    Artur, for example, I've used non metric ACI RC code and ACI reinforcing database:
    Product Support
    Artur.Kosakowski
    07-16-2012 02:14 AM in reply to: Romanich
    I'm sorry but the currently the values displayed in these fields are generated with use of the different tool and not taken from the indicated field of the bar database.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Moderator
    Romanich
    07-16-2012 02:19 AM in reply to: Artur.Kosakowski
    Can you add this issue to Wishlist?
    Product Support
    Artur.Kosakowski
    07-16-2012 02:25 AM in reply to: Romanich
    I have already done this. I always do :smileyhappy:
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
