• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Active Contributor
    MohammadZaman
    Accepted Solution
    Uplift Elimination
    232 Views, 4 Replies
    12-31-2012 07:26 AM
    Hi,Dear.
    I want to eliminate uplift force, but when I have seismic forces I can't define nonlinear case.
    What can I do now? I have attached robot file and screen shots.
    Could you please help me?
    Thank you.
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: Uplift Elimination
    01-02-2013 01:02 AM in reply to: MohammadZaman
    Please check:
    http://forums.autodesk.com/t5/Autodesk-Robot-Structural/problem-de-convergence-analyse-de-semelle/m-...
    http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Uplift/m-p/3320823/
    http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Barre-de-treillis-traction-compression-vs-s%...
    If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Active Contributor
    MohammadZaman
    01-02-2013 10:06 AM in reply to: Artur.Kosakowski
    Hello.
    But I used equivalent lateral force so there isn't need to use modal analysis and modal results combination.
    Seismic force in this way is constant and I defined it manually.
    I think it's one of disadvantages of robot.
    Is there any option to solve nonlinear calculations (not nonlinear analysis) with equivalent lateral seismic force?
    Thank you.
    Product Support
    Artur.Kosakowski
    01-03-2013 02:01 AM in reply to: MohammadZaman
    You are correct yet due to some restrictions in Robot internal architecture this is currently not possible. We have this in mind for the next releases.
    See http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Equivalent-static-analysis/td-p/3632154
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Product Support
    Artur.Kosakowski
    03-27-2013 06:47 AM in reply to: Artur.Kosakowski
    Introduced in SP4 for Robot 2103. Please check for the availability of this update at the beginning of the next week.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
