• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    stroxy
    Unsatisfactory Load Capacity of the Column
    317 Views, 6 Replies
    10-04-2012 04:24 AM
    According to the results I am not expecting to be seeing the "Unsatisfactory Load Capacity of the Column" message. Any reason why it could still be appearing?
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: Unsatisfactory Load Capacity of the Column
    10-04-2012 04:51 AM in reply to: stroxy
    Could you attach the file with this column please?
    Artur Kosakowski
    Support Specialist
    Product Support
    Product Support
    Artur.Kosakowski
    10-05-2012 01:09 AM in reply to: Artur.Kosakowski
    Large bi-directional shear for seismic combinations.
    Artur Kosakowski
    Support Specialist
    Product Support
    stroxy
    10-05-2012 03:40 AM in reply to: Artur.Kosakowski
    Error message still remains after manual modification of rebar to correct safety factor. See my earlier attachment.
    Product Support
    Artur.Kosakowski
    10-05-2012 03:47 AM in reply to: stroxy
    I'm not sure if I understand you correctly. What have you modified: spcaing of the stirrups? The best seems to be the increase of a cross section of the column itself.
    Artur Kosakowski
    Support Specialist
    Product Support
    stroxy
    10-05-2012 04:27 AM in reply to: Artur.Kosakowski
    Increased stirrup diameter in some cases and yes reduced stirrup spacing in others.  Your suggestion on increasing column dimension is however well noted ... but unfortunately  sometimes Architectural constraints determine how much column dimensions can be increased (the ever continuing saga between engineers and architects :manlol:)
    Also, Sometimes when one increases column dimensions, then huge plastic moments capacity develops in the column thus making it more difficult to satisfy capacity design requirement in shear.
    In  any case, I should expect the  error message to disappear once the safety ratios for the governing case is greater than 1 ... correct?
    Product Support
    Artur.Kosakowski
    10-05-2012 06:56 AM in reply to: stroxy
    Yes, the error should no longer be displayed  when all (for each of defined seismic combinations) safety ratios for shear are above 1.
    Artur Kosakowski
    Support Specialist
    Product Support
