Two problems
Two problems
andrea_pontiggia
Two problems
andrea_pontiggia
Hello, I have two problems:
-as I can orient the reference system more panels in the same direction automatically?
-in a model I find this problem, but I can not figure out where the model is wrong?
(i attach the file)
Cattura.JPGCatra.JPGthanks
Andrea
Romanich
answer for your first question is Yes.
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Rafal.Gaweda
Autodesk Support
Autodesk Support
I will check the model but take a look at this thread http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Error-Nr-100/m-p/3602456/highlight/true#M713...
Rafal Gaweda
Rafal.Gaweda
Autodesk Support
Autodesk Support
It is caused by not connected rigid link and some nodes not connected to bars located on claddings egdes \ corners.
Corrected file attached.
Rafal Gaweda
andrea_pontiggia
thank you very much
Andrea
