Autodesk Robot Structural Analysis
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Truss insertion error
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I am trying to insert a truss element from the library, but as soon as I finish editing the parameters,
and click apply,ok , it gives me an error(this is valid for all library elements)
I have tried going in different project types to see if this is the problem , but same error appears.
i have attached the error mesage,\
the error is :
Syntax incorect:line ignored
(2*%NF-1) %DIAGS "gamma" %DIAGSgamma
thanks in advance,
Dan,Suciu
Re: Truss insertion error
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
What language do you work with in Robot and what are the material and steel section databases declared in Job Preferences?
Artur Kosakowski
Support Specialist
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
the regional settings and printout language is Romanian, the working language is English
the material database is Eurocode with S460M M/L
the steel section database is ROMAN (for romanian steel products)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The library structures are based on the text files which are language dependent. For Romanian regional settings they have French name for steel (Acier) material assigned which doesn't exist in the Eurocode material database. Please add it in the way shown on the attached picture. Of course you should change the material of bars to the intended one after inserting the truss.
Artur Kosakowski
Support Specialist
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
thank you,
this has solved the problem
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
ROBOT97 Triangular Truss Type 1
TRU PLA
VER NON
VAR
SECTION "Dimensions" "d_tria1"
%UP = [BOOL] ?"0" : *First Diagonal Up
%SLL=]0.0,100000.0,ULENGTH] ?"30.0" : *Length L:
%SH=]0.0,100000.0,ULENGTH] ?"6.0" : *Height H:
%NF=[4,50] ?"6" : *Number of Fields:
%MEMB=[BOOL] ?"1" : *Continuous chord
%REL=[BOOL] ?"1" : *Moments Released
SECTION "More..." "d_tria1a"
%DIS=[0.0,1000.0,ULENGTH] ?"0.0" :*Distance D:
%DID=[0.0,1000.0,ULENGTH] ?"0.0" :*Distance D1:
SECTION "Sections" "d_tria1"
%CHORU= [profil]?"WT 12x52" : *Upper Chord -
%CHORUgamma= ?"0" : * - gamma angle =
%CHORL= [profil]?"WT 12x42" : *Lower Chord -
%CHORLgamma= ?"180" : * - gamma angle =
%DIAGS= [profil]?"DL 2x2x0.25" : *Diagonals -
%DIAGSgamma= ?"0" : * - gamma angle =
%POSTS= [profil]?"DL 2.5x2.5x0.25" : *Posts -
%POSTSgamma= ?"0" : * - gamma angle =
VAR END
NUM DIS
UNITS
Len=ft Force=kip
NOD
1 0 0
#if %DIS = 0.0
1 tra x=(%SLL/%NF) 2 G (%NF)
(%NF+2)r((%NF+4)/2-3) (%SLL/%NF) (2*%SH/%NF) (%SLL/2) (%SH)
(%NF+2+%NF/2)r((%NF+4)/2-4) (%SLL/2+%SLL/%NF) (%SH-2*%SH/%NF) (%SLL-%SLL/%NF) (2*%SH/%NF)
#else
1 tra x=(%SLL/%NF) z=(%DIS/%NF) 2 G (%NF)
(%NF+2)r((%NF+4)/2-3) (%SLL/%NF) (2*%SH/%NF+(%DIS/%NF)) (%SLL/2) (%SH+(%DIS/2))
(%NF+2+%NF/2)r((%NF+4)/2-4) (%SLL/2+%SLL/%NF) (%SH+(%DIS/2)-2*%SH/%NF+(%DIS/%NF)) (%SLL-%SLL/%NF) (2*%SH/%NF+%DIS-(%DIS/%NF))
#endif
#if %DID > 0.0
1 tra x=(%SLL/%NF) z=(%DIS/%NF+(2*%DID/%NF)) 2 G (%NF/2)
(%NF/2+1) tra x=(%SLL/%NF) z=(%DIS/%NF-(2*%DID/%NF)) (%NF/2+2) G (%NF/2)
#endif
ELE
#if %MEMB = 0
1r(%NF-1) 1 2
(%NF+1) 1 (%NF+2)
(%NF+2)r(%NF-3) (%NF+2) (%NF+3)
(2*%NF) (2*%NF) (%NF+1)
#if %UP = 1
(2*%NF+1)r(%NF/2-2) 2 (%NF+3)
(2*%NF+%NF/2)r(%NF/2-2) (%NF)by-1 (2*%NF-1)by-1
#else
(2*%NF+1)r(%NF/2-2) 3 (%NF+2)
(2*%NF+%NF/2)r(%NF/2-2) (%NF-1)by-1 (2*%NF)by-1
#endif
(3*%NF+1)r(%NF-2) 2 (%NF+2)
#else
#if %DID=0
1 1 (%NF+1)
2 1 (3*%NF/2+1)
3 (%NF+1) (3*%NF/2+1)
#else
1 1 (%NF/2+1)
2 (%NF/2+1) (%NF+1)
3 1 (3*%NF/2+1)
4 (%NF+1) (3*%NF/2+1)
#endif
#if %UP = 1
100r(%NF/2-2) 2 (%NF+3)
(100+%NF/2-1)r(%NF/2-2) (%NF)by-1 (2*%NF-1)by-1
#else
100r(%NF/2-2) 3 (%NF+2)
(100+%NF/2-1)r(%NF/2-2) (%NF-1)by-1 (2*%NF)by-1
#endif
200r(%NF-2) 2 (%NF+2)
#endif
PRO
STEEL
#if %MEMB = 0
1to(%NF) %CHORL "gamma" %CHORLgamma
(%NF+1) %CHORU "gamma" %CHORUgamma
(%NF+2)to(2*%NF-1) %CHORU "gamma" %CHORUgamma
(2*%NF) %CHORU "gamma" %CHORUgamma
(2*%NF+1)to(5*%NF/2-1) %DIAGS "gamma" %DIAGSgamma
(2*%NF+%NF/2)to(3*%NF-2) %DIAGS "gamma" %DIAGSgamma
(3*%NF+1)to(4*%NF-1) %POSTS "gamma" %POSTSgamma
#else
#if %DID=0
1 %CHORL "gamma" %CHORLgamma
2 3 %CHORU "gamma" %CHORUgamma
#else
1 2 %CHORL "gamma" %CHORLgamma
3 4 %CHORU "gamma" %CHORUgamma
#endif
#if %UP = 1
100to(100+%NF-3) %DIAGS "gamma" %DIAGSgamma
#else
#endif
200to(200+%NF-2) %POSTS "gamma" %POSTSgamma
#endif
REL
#if %REL = 1
#if %MEMB = 0
ELE 1to(%NF) ORI ry END ry
ELE (%NF+1) ORI ry END ry
ELE (%NF+2)to(2*%NF-1) ORI ry END ry
ELE (2*%NF) ORI ry END ry
ELE (2*%NF+1)to(5*%NF/2-1) ORI ry END ry
ELE (2*%NF+%NF/2)to(3*%NF-2) ORI ry END ry
ELE (3*%NF+1)to(4*%NF-1) ORI ry END ry
#else
#if %DID=0
ELE 1 ORI ry END ry
ELE 2 3 ORI ry END ry
#else
ELE 1 2 ORI ry END ry
ELE 3 4 ORI ry END ry
#endif
#if %UP = 1
ELE 100to(100+%NF-3) ORI ry END ry
#else
#endif
ELE 200to(200+%NF-2) ORI ry END ry
#endif
#endif
SUP
END
SUP
1 (%NF+1)
LOA
CASE # 1
(%NF+2)to(2*%NF) Fz=-1.0
END
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
salut aceeasi problema am si eu .....zi mi exact te rog **** ai facut ...am incercat sa aplic ce am vazut in imaginea aceea atasata si tot nu a mers ! ms fain
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
i have done what you say , and it doesn`t work ... pls give me details ... greetings !
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Could you give me the answers on the questions from the message 2?
Artur Kosakowski
Support Specialist
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I set all over the Romanian language ! and the second problem : i can` t set up ASD in Preferences (there is ASD and ROBOT - with robot checked). thanks
