• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    PatrickSt-Louis5310
    Trouble with the calculation of the soil allowable stress with RSA
    180 Views, 1 Replies
    11-08-2012 08:29 AM
    Bonjour,
                     problèmes de terminologie entre contrainte de rupture su sol et contrainte admissible du sol dans le module Semelle / SOL/ normes CSA/ACI/BS Geo de RSA, svp lisez les pièces jointes.Une réponse rapide serait appréciée.
    Merci
    Please use plain text.
    Product Support
    Re: Trouble with the calculation of the soil allowable stress with RSA
    11-13-2012 06:50 AM in reply to: PatrickSt-Louis5310
    Explanations for Patrick sent some time ago. Now some summary.
    1/ mistake in Help topic http://docs.autodesk.com/RSA/2013/ENU/filesROBOT/GUID-8CED5DA6-06CA-4043-ACA5-B982916AE2E8.htm
     instead of q_ult/3 ≤ q_SLS it should be q_ult/3 q_SLS
    2/ not explained in Help superposition&interaction of safety factors 3 (from the code) and user defined value of SF for Capacity from Geotechnical Options - such superposition is observed for Calculated/calculee soil stress
    Assuming that SF is safety factor defined for Capacity in Geotechnical Options it seems that:
    a/ for Allowable/"de rupture" soil stress
    SF ≤ qULT/qSLS
    b/ for Calculated/calculee soil stress
    SF ≤ qULT/3/qSLS
    Above effects reported to be fixed.
    If this post answers your question please click "Accept as Solution". It will help everyone to find answer more quickly!
    Pawel Pulak
    Support Specialist
    Product Support
    Autodesk, Inc.
