Autodesk Robot Structural Analysis
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Transforma tion of Panels to Solids
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have been working on a 3-D channel which has a varying cross-section. I modelled it using the "panel" property and then tried to convert it to a "solid" section. However, I was not able to do that.(See "Panel Model") It gives an error ("The solid has not been created").
Afterwards, I tried to model a single cross-section with the "panel" property and then extruded it, however the channel has varying cross-sections and my model was wrong. (See "Extrude Model")
Can you please propose a solution to my problem?
Thanks in advance
Re: Transforma tion of Panels to Solids
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
It should work : movie: http://screencast.com/t/3CXaPazGs749
Check whether all panels are flat and connected or send us file.
Rafal Gaweda
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Greetings,
is it possible to convert frames to solids?
Best Regards,
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
In case of steel bars you can import model to ASD Steel.
The if you want you can export it as ACIS *.sat file.
Rafal Gaweda
Product Support
