• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    New Member
    Transformation of Panels to Solids
    267 Views, 3 Replies
    07-04-2012 11:33 PM
    I have been working on a 3-D channel which has a varying cross-section. I modelled it using the "panel" property and then tried to convert it to a "solid"  section. However, I was not able to do that.(See "Panel Model") It gives an error ("The solid has not been created").
    Afterwards, I tried to model a single cross-section with the "panel" property and then extruded it, however the channel has varying cross-sections and my model was wrong. (See "Extrude Model")
    Can you please propose a solution to my problem?
    Thanks in advance
    Please use plain text.
    Product Support
    Re: Transformation of Panels to Solids
    07-05-2012 01:02 AM in reply to: trentunoo
    It should work : movie: http://screencast.com/t/3CXaPazGs749
    Check whether all panels are flat and connected or send us file.
    Rafal Gaweda
    Product Support
    Active Contributor
    02-12-2013 12:57 PM in reply to: RG_Adsk
    Greetings,
    is it possible to convert frames to solids?
    Best Regards,
    Product Support
    02-13-2013 12:29 AM in reply to: willjvizcaya
    In case of steel bars you can import model to ASD Steel.
    The if you want you can export it as ACIS *.sat file.
    Rafal Gaweda
    Product Support
