• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Product Support
    Artur.Kosakowski
    Re: Timber frame
    01-10-2013 04:03 AM in reply to: sj352
     How can I make sure that the beams carry the slab and not the other way around?
    I would check the deformation of the model. If the beam deforms as a 'whole' then the influence of beam is small or any. If you have 'separate' deflections in each of the fields then beams support the slab.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Please use plain text.
    Active Member
    Re: Timber frame
    01-10-2013 04:05 AM in reply to: sj352
    Will I do by "offsetting" beams under the slab?
    Product Support
    Artur.Kosakowski
    Re: Timber frame
    01-10-2013 04:12 AM in reply to: sj352
    Yes, this will 'increase' the stiffness of the beams.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
