• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Active Contributor
    Hallvard
    Timber columns - Initial deflection
    156 Views, 3 Replies
    10-25-2011 11:01 PM
    Hi
    Im working on a timber frame structure.
    When doing member definitions for timber columns I would like to apply a initial deflection. In practice all columns are not perfectly linear, and to the eccentricity will give a moment.
    How can I apply this initial deflection of columns?
    - Hallvard
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: Timber columns - Initial deflection
    10-25-2011 11:47 PM in reply to: Hallvard
    You can use the geometrical imperfection as shown on the attached picture.
    Artur Kosakowski
    Support Specialist
    Product Support
    Active Contributor
    Hallvard
    10-26-2011 06:53 AM in reply to: Artur.Kosakowski
    When using the Imperfection definition and "user defined" I have set e0 to 0,0025*L.
    When I open this dialog again e0 is 0,00*L
    I guess this means that e0 still is 0,0025*L, but all decimals are not showing.
    Correct?
    Product Support
    Artur.Kosakowski
    10-26-2011 07:01 AM in reply to: Hallvard
    Correct. You can check after changing the display format for the corresponding units in Job Preferences.
    Artur Kosakowski
    Support Specialist
    Product Support
