• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    New Member
    eunjucha
    Thermal Load
    298 Views, 1 Replies
    11-21-2011 05:51 PM
    I would like to know the formula of thermal load for steel you have on load definition based on BS5950 and BS8110.
    i try to put the temperature difference of dT 10C in TZ direction and run annalysis.
    i expect the emperature induced loads accounted for 10% to 20% of the total axial load though, it does account less than 1 to 2 % of the total axial load in the results.
    i have the formula of it , Pt, which is following
    Pt = 1.2xk x A x E x (12x10-6) x TD
    1.2 = load factor
    k = Thermal expansion factor = 0.8
    A = Gross area of section of steel
    E =Modulus of Elasticity of steel =  205 kN/mm2
    TD = temp difference (C)
    please help me up to solve that problem.
    thanks and regards,
    EunJu
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: Thermal Load
    11-21-2011 11:48 PM in reply to: eunjucha
    You should define TX instead. TZ (or TY) being the difference of temperature between top and bottom (left and right) fibers cause bending rather than tension/compression. See http://docs.autodesk.com/RSA/2012/ENU/filesROBOT/GUID-E4AB6038-D264-45C9-80F9-B06BC687794-448.htm
    Artur Kosakowski
    Support Specialist
    Product Support
