I am trying to model a baseplate with anchor bolts. How can I model the anchor bolts to act only in tension? For compression forces, the loads should be transferred to the base plate.
Solved by Artur.Kosakowski. Go to Solution.
You can use e.g. unidirectional support or a tension only bar.
