• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Distinguished Contributor
    AlexDT
    Tables - Sum of values
    168 Views, 5 Replies
    02-27-2012 01:36 AM
    What does "sum of val", "check val" precision mean? What does it show?
    Does Sum val(ue) give me the sum of forces responsable for the reactions?
    Please use plain text.
    Product Support
    Re: Tables - Sum of values
    02-27-2012 01:43 AM in reply to: AlexDT
    Check this help topic:
    http://docs.autodesk.com/RSA/2012/ENU/filesROBOT/GUID-E272460D-0B05-4F80-AF78-D6D9501131F-818.htm
    Rafal Gaweda
    Product Support
    AlexDT
    02-27-2012 02:20 AM in reply to: RG_Adsk
    Thanks! Sum of value is still not very clear to me though.
    "Sum of val. - An arithmetic sum of values of forces and moments for a given direction for the currently-filtered nodes."
    Sum of what values and which direction?
    Product Support
    02-27-2012 02:48 AM in reply to: AlexDT
    Take a look below:
    - selection in green
    - direction = columns (yellow, blue)
    Rafal Gaweda
    Product Support
    AlexDT
    02-27-2012 03:04 AM in reply to: RG_Adsk
    Thanks. It is simply the total of the reactions of the selected nodes then?
    In my case I selected all the nodes, but the the sum of value for the moments are not  equal to the sum of forces.
    In fact I changed all my supports to pinned so I didnt have any moments in them, but the sum of reaction for those nodes still remain? I dont get how that adds up.
    Product Support
    02-27-2012 04:28 AM in reply to: AlexDT
    So either you have elastic supports  \ ground on model or you are looking on nonconverged results of nonlinear case.
    Example below
    Rafal Gaweda
    Product Support
