Table saving missing path
Hi all
From the steel design table, is there any posibility to save the results as .cvs ?
1          How to specify a folder to save the results from ARSA?
You will find in the second file, the diference between the buttons in the shorter list it is no more available the button "Change"
Thanks a lot in advance
Artur.Kosakowski
Autodesk Support
Autodesk Support
1. Change is for the selected 'line' only.
2. This is a label rather than a path Smiley Happy Intended for the printout composition.
3. Save in Word and then copy via clipboard to Excel
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
