TABLE FILTER
TABLE FILTER
StefanoPasquini6790
Advisor Advisor
TABLE FILTER
StefanoPasquini6790
Hi group members,
Anyone of you know the reason why the filter for the selection of tables doesn't works on Robot 2013? For example, if I select two beams and ask for the table of forces only on them, Robot returns the table of forces for all the bars of the structure. Is this a bug for the 2013 version? Is there some setting to do?
PasProStudio
www.pasquiniprogetti.eu
Structural + Detailing engineers
Rafal.Gaweda
Autodesk Support
Autodesk Support
It works like that: http://screencast.com/t/Q3TH4FuQk
Rafal Gaweda
StefanoPasquini6790
Hi Rafal,
i perfectly know how to use this command, I'm a Robot user since version 17.5. I only pointed out that on my PC, with   the 2013 version installed, this function does not work...as in the previous version...
Regards
PasProStudio
Rafal.Gaweda
Autodesk Support
Autodesk Support
clear windows %temp% folder , clear  cfgusr folder before next robot start
Rafal Gaweda
StefanoPasquini6790
Thanks for your suggestion, i've removed only the *.tbl files in the cfgusr folder, and everything it work correctly. When i clear all the content of the cfgusr folder i lose all the personalization for command, keyboard, visualization and much much more...
Thk
PasProStudio
