• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Valued Contributor
    StefanoPasquini6790
    TABLE FILTER
    106 Views, 4 Replies
    08-01-2012 07:54 AM
    Hi group members,
    Anyone of you know the reason why the filter for the selection of tables doesn't works on Robot 2013? For example, if I select two beams and ask for the table of forces only on them, Robot returns the table of forces for all the bars of the structure. Is this a bug for the 2013 version? Is there some setting to do?
    Please use plain text.
    Product Support
    Re: TABLE FILTER
    08-01-2012 07:57 AM in reply to: StefanoPasquini6790
    It works like that: http://screencast.com/t/Q3TH4FuQk
    Rafal Gaweda
    Product Support
    Valued Contributor
    StefanoPasquini6790
    Re: TABLE FILTER
    08-01-2012 08:45 AM in reply to: RG_Adsk
    Hi Rafal,
    i perfectly know how to use this command, I'm a Robot user since version 17.5. I only pointed out that on my PC, with   the 2013 version installed, this function does not work...as in the previous version...
    Regards
    Product Support
    Re: TABLE FILTER
    08-02-2012 12:16 AM in reply to: StefanoPasquini6790
    clear windows %temp% folder , clear  cfgusr folder before next robot start
    Rafal Gaweda
    Product Support
    Valued Contributor
    StefanoPasquini6790
    Re: TABLE FILTER
    08-02-2012 05:48 AM in reply to: RG_Adsk
    Thanks for your suggestion, i've removed only the *.tbl files in the cfgusr folder, and everything it work correctly. When i clear all the content of the cfgusr folder i lose all the personalization for command, keyboard, visualization and much much more...
    Thk
