Autodesk Robot Structural Analysis
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Sum of harmonic loads - square rod of the sum of squares
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi!
I have static loads (#1 to #13 on attached picture) and harmonic loads (#15 to #17).
Is it possible in Robot to generate Automatic Combination, where the sum of harmonic loads will be calculated as the square root of the sum of squares:
Wp3 = √[(#15)^2+(#16)^2+(#17)^2]
Thank you in advance!
Re: Sum of harmonic loads - square rod of the sum of squares
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi, maybe this help you:
http://docs.autodesk.com/RSA/2012/ENU/filesROBOT/G
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi, Romanich!
Thank you for reply! It looks like the answer I need...
But is it possible to use this Quadratic Combination at the same time with Automatic Combinations?
I meen that this CQC will be as one of the loads in the table of combinations, generated automatically.
As far as I remember, we can use either Manual or Automatic...
