• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Valued Contributor
    Sub-dividing floor slab object
    88 Views, 2 Replies
    05-03-2012 10:57 PM
    Is is possible to define a floor slab corresponding to the total area and then sub-divide it afterwards. I'm primarily interested in generating seperate regions internally.
    I have a reduced slab depth in some internal regions and I would prefer to avoid defining a floor plate consisting of say 10 seperate objects as I'm having problems with meshing this. When I define these seperate members they're not snapped to the same node (fractions of a millimeter apart).
    Jesper
    Please use plain text.
    Valued Mentor
    tony.ridley
    Re: Sub-dividing floor slab object
    05-03-2012 11:06 PM in reply to: Jesper.Jensen
    Turn off snap to node and snap to grid then draw with snap to mid/end point.  You can't subdivide panels
    Product Support
    05-06-2012 11:31 PM in reply to: Jesper.Jensen
    You can create internal panels or create panels from FEs selection (limitation : no inner holes \ openinng in selection)
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
